It is currently Tue Aug 12, 2025 10:16 am
 Post subject: flattop observation
PostPosted: Sun Jan 31, 2010 2:39 am
Recently I have been restoring a 1948 Martin D-28. Brazilian back and sides, sitka top and bracing. Here is a couple pics of the top with a rule showing the top's radius.
My guess, this was a truly flat top when it was built. No radius dish involved... the back was in two pieces so I don't have any measure for it.
Anyone work at Martin back then and know for sure??
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
 Post subject: Re: flattop observation
PostPosted: Sun Jan 31, 2010 7:36 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
My 1955 D18 has a radius on the back. The top's pretty flat, with a slight belly behind the bridge. If it was radiused it was pretty flat. I suspect John Arnold, or John Hall (Bluescreek) could tell you exactly what was done back then.
PostPosted: Sun Jan 31, 2010 8:00 am
the tops had a large radii of about 42 feet on the bracing. the top was flat but was at a slight angle , it wasn't dead square. The lower belly is to be there. With this being a 55 don't try and change much , if you are retopping it you can re establish the geometry to a point.
PostPosted: Sun Jan 31, 2010 12:36 pm
Thanks Woody and John,
John, I won't have to replace the top on this '48, but some of the top bracing will have to be removed, cleaned up and re-glued. Because of the geometry of the top, should the neck angle be reset differently then current practices (about a half inch at the bridge location... as in your youtube video). I'm not sure how much these tops at this radius raise up with string tension.
thanks.
Chris Oliver
Infinity Luthiers
...in the shop.
PostPosted: Sun Jan 31, 2010 1:55 pm
It is normal to adjust the angle with a wedge under the fretboard extension. Trying to adjust that angle can cause you yo thin the top where you don't want to thin it. Ebony makes this a good clean fix.
PostPosted: Sun Jan 31, 2010 2:20 pm
Last Name: Cox
Correct me if I am wrong here... but my understanding is that back in the day, Martin made the "Radius" in the top by springing the top onto braces with curved profiles (Like in the Cumpiano book.)
It wouldn't be too hard to replicate that method on the Restoration......
I think if it was me, I would reset the neck as a matter of course when replacing a bunch of bracing... especially if you are correcting a sunken top in like shown.
PostPosted: Sun Jan 31, 2010 5:41 pm
The first thing you need is to get the bracing reglued. One nice thing is that you are dealing with HHG . Once the braces are done you need to address the reset. You do want to work the neck angle so you should be to that 1/2 inch line.
What is the condition of the bridge and the height of that. ? Call me if you need to
PostPosted: Sun Jan 31, 2010 7:26 pm
Sorry John... this '48 is in need of a restore because of its participation in a flood. Someone had previously tried to work on this unit. The bridge and fretboard are missing. Everything else is mostly intact. Also, they decided to dump a pot of hide glue in the top bracing to stabilize them... I guess? Here is a photo of the top.
Nice...
I have alot of hide glue to remove, not to mention flood funk.
Chris Oliver
Infinity Luthiers
...in the shop.
PostPosted: Sun Jan 31, 2010 7:38 pm
you can do a good restore on this. It is a great guitar to get back into shape. You should get this in a mold.
PostPosted: Sun Jan 31, 2010 8:12 pm
John, I agree... recently I removed the neck,
now I've got to clean up the inside, then get it in a mold.
Chris Oliver
Infinity Luthiers
...in the shop.
Users browsing this forum: No registered users and 49 guests
